Fields value disappear after has been filled when running Pega Robotics Automation
Hi.
I have a problem when running a Pega Robitics Automation. In the main form on my application there are two fields that must be filled by the automation (see picture 1 on pdf file attached). The field CPF and the field Contato are filled by the automation when running, but just one moment after its has been filled, the values of these fields just disappear (see picture 2 on pdf file attached).
When I toggle a breakpoint in some point on the process (see picture 3 on pdf file attached) and run the automation and after the breakpoint stop just press F5 to continue, the fields value does not disappear. This is pretty weird: leaving the breakpoint on the process the automation run normally. When the breakpoint is deleted, the values on the field just vanished.
Any help to solve this issue is very appreciate.
