Capgemini
BR
Last activity: 31 Oct 2023 8:54 EDT
Change stage create cases instances empty
Hello ,
I'm facing a problem that seems very strange to me in my version 8.6.1
I have a case that when it advances to the stages, it creates instances of the same case in the work table - but they are empty.
In one of these stages I execute a flow, where depending on the decision, it triggers a stage change through the Change Stage shape.
However, it changes stage, but the case screen disappears, remaining empty.
This stage he moves to, he just has the idea of solving the case. There's no flow or anything, you just enter the internship and solve the case.
I noticed that even if I change my strategy and add an assignment flow, the screen appears for my user, he can close the case, however, I noticed that he continues to generate empty instances of the same case in the corresponding work class.
I got the following error logs on my pdc:
Error evaluating visible when ' o2&& o2&& o2&& wxpzIsTabbedScreenFlow o2> rxpyFlowData.pxNodeCount ci1 o1! wxpxIsOfflinePackaging o1! wxpzIsCaseWideAction' .
Hello ,
(root cause)
Type com.pega.pegarules.pub.PRRuntimeException
Message Error evaluating visible when ' o2&& o2&& o2&& wxpzIsTabbedScreenFlow o2> rxpyFlowData.pxNodeCount ci1 o1! wxpxIsOfflinePackaging o1! wxpzIsCaseWideAction' .
Stack at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuntimeImpl.handleEvaluateWhen(AutoStreamRuntimeImpl.java:1275)
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.ContextProcessor.updateWhenInContextData(ContextProcessor.java:2437)
at
(top level exception)
Message Section 'pyActivityPage' execution error on page 'pyWorkPage' of class 'BS-RetencaoSPG-Work-Retencao'. : Error evaluating visible when ' o2&& o2&& o2&& wxpzIsTabbedScreenFlow o2> rxpyFlowData.pxNodeCount ci1 o1! wxpxIsOfflinePackaging o1! wxpzIsCaseWideAction' .
com.pega.pegarules.pub.PRRuntimeExceptioncom.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuntimeImpl.handleEvaluateWhen!1275:com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.ContextProcessor.updateWhenInContextData!2437:com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.RuntimeContextTree.executeVisibleWhen!356:com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.RuntimeContextTree.beginVi...
attached the log detail
