case type does not yet have any fields defined.
What is this section is used for and what is this message about?
Hi ,
That section is 'pyNewCaseContainer'.
By default we see, one of the standard harnesses, 'New' with the section pyNewCaseContainer when a case is created.
The purpose of 'New' harness is it supports entry of a new work item and the start of a flow rule execution for that work item.
You can skip this screen by checking "Skip 'Create' view when users create a new case" checkbox available in the settings tab of the case designer.
Thank You.
Hi ,
Thank You.
Also, we can say the field which we are adding under "Data model" in the Case type , it will reflect under the Case Information
