Case Instance retrieval
Can we retrieve deleted case instances?
Thank you!!
***Edited by Moderator Marissa to update Capability tags****
Thank you!!
By delete , if you mean deletion from the table corresponds to the case class , it cant be retrieved as it is hard delete. unless untill there is a backup taken for that table
To avoid this situation , we can have below solution:
The cases which are ready for purging can have some status defined based on the purge policy defined by business , which will ensure the cases remain with us as per conditions of business , Once purge policy is met we can go ahead and delete those instances as per business approval.
