American Express
Last activity: 22 Nov 2016 23:46 EST
Cascading dynamic select issue - refresh section (run activity) combination is not working properly
HI Team,
We are having an issue after upgrade, we have a cascading dynamic select where on the actions tab of the 1st dynamic select we have - refresh section (run activity) and we have implemented the logic in the activity to populate the values in the second drop down.
Issue :
Sometimes reload section is triggering first and later activity steps are getting executed which has caused to populate the 2nd drop down as an empty value.
Ideally Refresh Section - (Run activity) combination should first trigger the 'activity steps' to execute and later the 'reload section' should trigger to populate the values.
But here we are sometimes facing an issue like Reload Section is triggering first and later the activity steps are getting executed - is it a product Issue?
Manoj
You might consider refactoring your cascading dropdowns to use a pattern as shown here: https://community.pega.com/video-library/support-guide-how-troubleshoot-issues-cascading-dropdowns
This is generally much more performant than performing section refreshes.
