Accenture Pte Ltd
SG
Last activity: 5 Feb 2019 5:54 EST
BIX: pxExtractDateTime & pxExtractIdentifier not populated
I've set up the BIX to extract the properties to the database table, however the pxExtractDateTime and pxExtractIdentifier is not getting populated in the table. Is there anything that I'm required to configure to populate the 2 columns?
Thanks!
Are the properties are getting extracted successfully?
Are you running BIX from command line?
Can you try to extract to different source (like CSV/ XML) and see if you are able to get these values?
Venkat
Accenture Pte Ltd
SG
Hi! Thanks for the reply!
All properties are extracted properly except for the pxExtractDateTime and pxExtractIdentifier.
I'm running BIX using the Pega Extract.
I've tried extracting to CSV and XML. pxExtractDateTime and pxExtractIdentifier is both extracted in the CSV but not in the xml.
Accenture Pte Ltd
SG
I still require assistance on this topic... thanks...
Hi WeiLin,
I'm able to replicate the issue. pxExtractIdentifier, pxExtractDateTime are coming in CSV, DB extract but not in XML extract.
In fact, this is a bug in CSV extract to fetch pxExtractIdentifier, pxExtractDateTime columns. We have PegaCSVUtility to stop fetching these columns in CSV extract.
Please let us know what is the need for you to fetch these.
Venkat
Accenture Pte Ltd
SG
Thanks for the reply. As I would like to use the pxExtractDateTime to find out when the record was extracted, it would be necessary to have that property. Would there be anyway to retrieve that property in the DB extract?
Thank you.
Lloyds Banking Group
Thanks for this post. What changes do i need to do in the BIX Extract rule in 7.3.1 to stop fetching pxExtractIdentifier and pxExtractDateTime columns please?
Deepak Singh
Commonwealth Bank of Australia
i need to exclude fetching pxextractdatetime& pxextractidentifier into the csv files. is there a way to exclude these two fields from the extract?
Ashwani Mishra
I believe there is a PegaCSVUtility that can remove the pxextractdatetime& pxextractidentifier from cvs.
Regards
Simon
