BIX Extract sometimes does not run even stand alone not from Agent rule - Getting expection - ERROR - SQL error getting the next row to be extracted
Pega Version 7.1.8
BIX Version -7.1
Application Server - Tomcat
DB - DB2.
We are getting below error durng BIX run either sometimes manually or via agent.
SQL error getting the next row to be extracted: errorCode = -4470 errorMessage:[jcc][t4][10120][10898][4.18.60] Invalid operation: result set is closed. ERRORCODE=-4470, SQLSTATE=null
2016-12-05 17:12:19,776 [ PegaRULES-Batch-2] [ ] [ Application:01.01.02] ( internal.access.ExtractImpl) ERROR - Could not return target db statements
java.sql.SQLException: Connection has already been closed.
at org.apache.tomcat.jdbc.pool.ProxyConnection.invoke(ProxyConnection.java:117)
at org.apache.tomcat.jdbc.pool.JdbcInterceptor.invoke(JdbcInterceptor.java:108)
at org.apache.tomcat.jdbc.pool.DisposableConnectionFacade.invoke(DisposableConnectionFacade.java:81)
at com.sun.proxy.$Proxy5.setAutoCommit(Unknown Source)
Sometimes the BIX stopped working with the below error in the log.
Pega Version 7.1.8
BIX Version -7.1
DB - DB2.
Batch Update Exception: [jcc][t4][102][10040][4.18.60] Batch failure. The batch was submitted, but at least one exception occurred on an individual member of the batch.
Use getNextException() to retrieve the exceptions for specific batched elements. ERRORCODE=-4229, SQLSTATE=null
com.ibm.db2.jcc.am.BatchUpdateException: [jcc][t4][102][10040][4.18.60] Batch failure. The batch was submitted, but at least one exception occurred on an individual member of the batch.
