Automating application packaging wizard using script
looking for options to automate application packaging wizrd using script.
You can only use the prpcUtils command utility with the exportRAP option, to export the rules and data associated with a specific Rule-Admin-Product instance.
Hi Krishna,
Looking for options to automate lock and roll rulesets using script.
