Endeavour Energy
Last activity: 28 Jun 2017 7:50 EDT
Using prpcServiceUtils and Jenkins for automated application deployment
Hi , I am trying to export RAP via Jenkins using prpsserviceutlis Build job is throwing below error Started by user admin [EnvInject] - Loading node environment variables. [EnvInject] - Preparing an environment for the build. [EnvInject] - Keeping Jenkins system variables. [EnvInject] - Keeping Jenkins build variables. [EnvInject] - Injecting as environment variables the properties content SystemName=$BUILD_TAG SourcePassword=rules SourceHost=http://localhost:8080 SourceUser=uplusadmin [EnvInject] - Variables injected successfully. [EnvInject] - Injecting contributions. Building in workspace E:\Jenkins\workspace\RAPOut [EnvInject] - Unset unresolved 'USERNAME' variable. [jenkins] $ cmd.exe /C "ant.bat -file Jenkins-build.xml -DproductVersion=20150604.094600 -DproductName=UPlusApp exportprops && exit %%ERRORLEVEL%%" Buildfile: E:\Jenkins\workspace\RAPOut\scripts\samples\jenkins\Jenkins-build.xml exportprops: [propertyfile] Creating new property file: E:\Jenkins\workspace\RAPOut\scripts\utils\jenkins-RAPOut-13_export.properties BUILD SUCCESSFUL Total time: 0 seconds [RAPOut] $ cmd /c call C:\WINDOWS\TEMP\hudson5110610964616011760.bat E:\Jenkins\workspace\RAPOut>E:\Jenkins\workspace\RAPOut\scripts\utils\prpcServiceUtils.bat export --connPropFile E:\Jenkins\workspace\RAPOut\jenkins-RAPOut-13_import.properties --artifactsDir E:\Jenkins\workspace\RAPOut Invoke our ant script, passing in the arguments as
Hi , I am trying to export RAP via Jenkins using prpsserviceutlis Build job is throwing below error Started by user admin [EnvInject] - Loading node environment variables. [EnvInject] - Preparing an environment for the build. [EnvInject] - Keeping Jenkins system variables. [EnvInject] - Keeping Jenkins build variables. [EnvInject] - Injecting as environment variables the properties content SystemName=$BUILD_TAG SourcePassword=rules SourceHost=http://localhost:8080 SourceUser=uplusadmin [EnvInject] - Variables injected successfully. [EnvInject] - Injecting contributions. Building in workspace E:\Jenkins\workspace\RAPOut [EnvInject] - Unset unresolved 'USERNAME' variable. [jenkins] $ cmd.exe /C "ant.bat -file Jenkins-build.xml -DproductVersion=20150604.094600 -DproductName=UPlusApp exportprops && exit %%ERRORLEVEL%%" Buildfile: E:\Jenkins\workspace\RAPOut\scripts\samples\jenkins\Jenkins-build.xml exportprops: [propertyfile] Creating new property file: E:\Jenkins\workspace\RAPOut\scripts\utils\jenkins-RAPOut-13_export.properties BUILD SUCCESSFUL Total time: 0 seconds [RAPOut] $ cmd /c call C:\WINDOWS\TEMP\hudson5110610964616011760.bat E:\Jenkins\workspace\RAPOut>E:\Jenkins\workspace\RAPOut\scripts\utils\prpcServiceUtils.bat export --connPropFile E:\Jenkins\workspace\RAPOut\jenkins-RAPOut-13_import.properties --artifactsDir E:\Jenkins\workspace\RAPOut Invoke our ant script, passing in the arguments as collected Buildfile: E:\Jenkins\workspace\RAPOut\scripts\utils\prpcserviceutilsWrapper.xml [echo] *** JVM Arguments -XX:MaxHeapSize=1280m -XX:MaxMetaspaceSize=512m *** -init: [delete] Deleting directory E:\Jenkins\workspace\RAPOut\scripts\utils\generated [mkdir] Created dir: E:\Jenkins\workspace\RAPOut\scripts\utils\generated [pega:propertyparser] Reading Properties from : E:\Jenkins\workspace\RAPOut\scripts\utils/prpcServiceUtils.properties [pega:propertyparser] pega.rest.server.url=http://<host name>:<port number>/<context>/PRRestService/<tenant url hash> [pega:propertyparser] pega.rest.username= [pega:propertyparser] pega.rest.password=***** [pega:propertyparser] pega.rest.proxy.host= [pega:propertyparser] pega.rest.proxy.port= [pega:propertyparser] pega.rest.proxy.username= [pega:propertyparser] pega.rest.proxy.password=***** [pega:propertyparser] pega.rest.proxy.domain= [pega:propertyparser] pega.rest.proxy.workstation= [pega:propertyparser] pega.rest.response.type=json [pega:propertyparser] user.temp.dir=C:/pega_temp [pega:propertyparser] export.archiveName= [pega:propertyparser] export.productName= [pega:propertyparser] export.productVersion= [pega:propertyparser] export.applicationVersion= [pega:propertyparser] export.applicationName= [pega:propertyparser] export.branchName= [pega:propertyparser] export.branchAppContext= [pega:propertyparser] export.async=true [pega:propertyparser] expose.includedClasses= [pega:propertyparser] expose.includeDescendents=true [pega:propertyparser] expose.excludedClasses= [pega:propertyparser] expose.excludeDescendents=true [pega:propertyparser] expose.startKey= [pega:propertyparser] expose.endKey= [pega:propertyparser] expose.startDate= [pega:propertyparser] expose.endDate= [pega:propertyparser] expose.reindex=true [pega:propertyparser] expose.reindexType=nonpega [pega:propertyparser] expose.commitRate=100 [pega:propertyparser] expose.numOfThreads=1 [pega:propertyparser] expose.async=true [pega:propertyparser] import.archive.path= [pega:propertyparser] import.mode=import [pega:propertyparser] import.existingInstances=skip [pega:propertyparser] import.nofailonerror=false [pega:propertyparser] import.commitRate=100 [pega:propertyparser] import.compileLibraries=true [pega:propertyparser] import.allowImportWithMissingDependencies=false [pega:propertyparser] import.codesetName=Customer [pega:propertyparser] import.codesetVersion=06-01-01 [pega:propertyparser] import.async=true [pega:propertyparser] import.trackData=true [pega:propertyparser] manageTrackedData.operation= [pega:propertyparser] hotfix.operation= [pega:propertyparser] hotfix.dlFilePath= [pega:propertyparser] hotfix.catalogPath= [pega:propertyparser] hotfix.bypassSchema=false [pega:propertyparser] hotfix.force=false [pega:propertyparser] hotfix.async=true [pega:propertyparser] getstatus.jobID= [pega:propertyparser] getstatus.operationName= [pega:propertyparser] manageRestorePoints.action= [pega:propertyparser] manageRestorePoints.restorePointName= [pega:propertyparser] manageRestorePoints.restorePointLabel= [pega:propertyparser] rollback.restorePointName= [pega:propertyparser] rollback.action=SystemRollback [pega:propertyparser] rollback.async=true [pega:propertyparser] rollback.downloadLogToFile=true [pega:propertyparser] updateAccessGroup.applicationName= [pega:propertyparser] updateAccessGroup.applicationVersion= [pega:propertyparser] updateAccessGroup.groupList= [mkdir] Created dir: C:\WINDOWS\TEMP\PegaInstallTemp-13-June-2017-20.04.19 [pega:hasenoughspace] Found 58333408KB of free space on 'C:\WINDOWS\TEMP\' -processInstances: [echo] Performing export on multiple instance(s) [echo] argument line [echo] -action export -propFileDir E:\Jenkins\workspace\RAPOut\scripts\utils/generated -poolSize ${prpcserviceutils.pool.size} -requestTimeOut ${prpcserviceutils.request.timeout} -tempDir C:\WINDOWS\TEMP\/PegaInstallTemp-13-June-2017-20.04.19 -artifactsDir E:\Jenkins\workspace\RAPOut [echo] export [echo] [echo] Reading connection information from E:\Jenkins\workspace\RAPOut\jenkins-RAPOut-13_import.properties [pega:propertyfilegenerator] pega.rest.server.url=http://<host name>:<port number>/<context>/PRRestService/<tenant url hash> [pega:propertyfilegenerator] pega.rest.username= [pega:propertyfilegenerator] pega.rest.password=***** [pega:propertyfilegenerator] pega.rest.proxy.host= [pega:propertyfilegenerator] pega.rest.proxy.port= [pega:propertyfilegenerator] pega.rest.proxy.username= [pega:propertyfilegenerator] pega.rest.proxy.password=***** [pega:propertyfilegenerator] pega.rest.proxy.domain= [pega:propertyfilegenerator] pega.rest.proxy.workstation= [pega:propertyfilegenerator] pega.rest.response.type=json [pega:propertyfilegenerator] user.temp.dir=C:/pega_temp [pega:propertyfilegenerator] export.archiveName= [pega:propertyfilegenerator] export.productName= [pega:propertyfilegenerator] export.productVersion= [pega:propertyfilegenerator] export.applicationVersion= [pega:propertyfilegenerator] export.applicationName= [pega:propertyfilegenerator] export.branchName= [pega:propertyfilegenerator] export.branchAppContext= [pega:propertyfilegenerator] export.async=true [pega:propertyfilegenerator] expose.includedClasses= [pega:propertyfilegenerator] expose.includeDescendents=true [pega:propertyfilegenerator] expose.excludedClasses= [pega:propertyfilegenerator] expose.excludeDescendents=true [pega:propertyfilegenerator] expose.startKey= [pega:propertyfilegenerator] expose.endKey= [pega:propertyfilegenerator] expose.startDate= [pega:propertyfilegenerator] expose.endDate= [pega:propertyfilegenerator] expose.reindex=true [pega:propertyfilegenerator] expose.reindexType=nonpega [pega:propertyfilegenerator] expose.commitRate=100 [pega:propertyfilegenerator] expose.numOfThreads=1 [pega:propertyfilegenerator] expose.async=true [pega:propertyfilegenerator] import.archive.path= [pega:propertyfilegenerator] import.mode=import [pega:propertyfilegenerator] import.existingInstances=skip [pega:propertyfilegenerator] import.nofailonerror=false [pega:propertyfilegenerator] import.commitRate=100 [pega:propertyfilegenerator] import.compileLibraries=true [pega:propertyfilegenerator] import.allowImportWithMissingDependencies=false [pega:propertyfilegenerator] import.codesetName=Customer [pega:propertyfilegenerator] import.codesetVersion=06-01-01 [pega:propertyfilegenerator] import.async=true [pega:propertyfilegenerator] import.trackData=true [pega:propertyfilegenerator] manageTrackedData.operation= [pega:propertyfilegenerator] hotfix.operation= [pega:propertyfilegenerator] hotfix.dlFilePath= [pega:propertyfilegenerator] hotfix.catalogPath= [pega:propertyfilegenerator] hotfix.bypassSchema=false [pega:propertyfilegenerator] hotfix.force=false [pega:propertyfilegenerator] hotfix.async=true [pega:propertyfilegenerator] getstatus.jobID= [pega:propertyfilegenerator] getstatus.operationName= [pega:propertyfilegenerator] manageRestorePoints.action= [pega:propertyfilegenerator] manageRestorePoints.restorePointName= [pega:propertyfilegenerator] manageRestorePoints.restorePointLabel= [pega:propertyfilegenerator] rollback.restorePointName= [pega:propertyfilegenerator] rollback.action=SystemRollback [pega:propertyfilegenerator] rollback.async=true [pega:propertyfilegenerator] rollback.downloadLogToFile=true [pega:propertyfilegenerator] updateAccessGroup.applicationName= [pega:propertyfilegenerator] updateAccessGroup.applicationVersion= [pega:propertyfilegenerator] updateAccessGroup.groupList= BUILD FAILED E:\Jenkins\workspace\RAPOut\scripts\utils\prpcserviceutilsWrapper.xml:173: Connection Property file E:\Jenkins\workspace\RAPOut\jenkins-RAPOut-13_import.properties is not a valid file Total time: 0 seconds Exiting with Error Build step 'Execute Windows batch command' marked build as failure Finished: FAILURE
Below is the content of jenkins-RAPOut-13_import.properties present at E:\Jenkins\workspace\RAPOut\scripts\utils
#Tue, 13 Jun 2017 20:04:17 +1000
jenkins-RAPOut-13.pega.rest.server.url=http\://localhost\:8080/prweb/PRRestService/
jenkins-RAPOut-13.pega.rest.username=uplusadmin
jenkins-RAPOut-13.pega.rest.password=rules
jenkins-RAPOut-13.export.archiveName=UPlusApp20150604.094600
jenkins-RAPOut-13.export.productName=UPlusApp
jenkins-RAPOut-13.export.productVersion=20150604.094600
jenkins-RAPOut-13.export.applicationName=${applicationName}
jenkins-RAPOut-13.export.applicationVersion=${applicationVersion}
jenkins-RAPOut-13.export.async=false
