Last activity: 8 Jun 2021 12:48 EDT
Automatic schema update fails but deployement runs succesfully. No error in Pipeline
Deploying a new application on the Staging environment for the first time we have included the new schema definitions in the deployment and expect Pega to update the schema. Due to insufficient privileges this process ran into an error. This problem was easy to solve so had no problems in later deployments. ButI did not expect that the deployment continues while the SQL import failed like in manual imports. And besides that the pipeline just continues the process and ended succesfully.
So my questionis: Why is the failed SQL import not reported to the deployment manager and is the process not stopped with an error?
Greetings
Bertus
