Instellars Global Consulting Pvt.Ltd
Last activity: 2 Mar 2020 8:32 EST
I have 3 questions about attachments Part.
1. In a Work object when we add Attachments Where it will get Stored?
2. we do have Data-WorkAttach-File & Link-Attachment Class. Why we do have two attachments class?
3. There are some attachments in DB. Based on Value i wanted to add a attachment to Work Object. How could i achieve this.
The system stores attachments in instances of these concrete classes, subclasses of the Data-Work Attach- class:
Data-WorkAttach-File, Data-WorkAttach-Note, Data-WorkAttach-URL, Data-WorkAttach-ScreenShot, Data-WorkAttach-ScanDocument, Data-WorkAttach-ECM
By default, work item attachments are stored as rows of the
pc_data_workattachtable.Link-Attachment class instances store pzInsKey 's of the attachment and the work object in an instance so that we will know that the attachment and work object are linked.
Answer1:
If the attachment is of type File, then it is stored as an instance of Data-WorkAttach-File in pc_data_workattach table.
Answer2:
A file attachment for a work object is an instance of Data-WorkAttach-File. The attachment is connected to its work object through a link object, an instance of Link-Attachment.
Answer3:
Using Link-Objects method you can add attachment to a work object.
You can refer to below articles for more details.
https://community.pega.com/knowledgebase/articles/process/how-create-activities-attach-files-work-objects
Answer1:
Answer2:
Answer3:
https://community.pega.com/sites/default/files/help_v63sp1/Content/methods/link-objects/link-objects.htm
https://community.pega.com/sites/default/files/help_v718/concepts/casemanagement/con_conceptsattachments.htm
