TATA CONSULTANCY SERVICES
Last activity: 24 May 2017 11:14 EDT
Async IO operation failed (3), reason: RC: 107 Transport endpoint is not connected
Hi, We are seeing the below errors in the logfiles.
Problem retrieving input data: [java.io.IOException: Async IO operation failed (3), reason: RC: 107 Transport endpoint is not connected
Could see multiple PDN Articles with references to the above exception.
https://pdn.pega.com/support-articles/sockettime-out-and-io-exception-pega-logiles
https://pdn.pega.com/support-articles/user-not-able-login-avaya-using-pega-telephony-toolbar
All of them point to same Resolution : This issue is resolved by making the following change to the PRPC operating environment: Increased the WebSphere parameters ConnectionIOTimeOut and ConnectionKeepAliveTimeout.
Even we want to apply the same Fix for our Client Application Environment which is running on Websphere 7.X . But before that I've read IBM HELP Article regarding these settings.
IBM Recommends - to configure this settings only if your Websphere Application Version is Pre 6.0 which means this Setting is not applicable for Websphere 7.X ? or Higher versions above 6.X ?
Please see below
Can anyone review this & advise further on how to proceed ?
