IKOR
Last activity: 7 Feb 2017 15:05 EST
Archive/Purge Issues
Hi there,
I am in v7.1.9 and ran Purging wizard for a simple test ( Non Production environment)
1.I configured the Purging wizard using Configuration utility.
2. I purged all the work items resolved from past 95 days.
I did a simple run and ended up with the following result.
Interval Started at 7/02/17 11:13 AM and lasted 19 seconds.
1 items were purged
52 records were purged
Files created Errors encountered
To know what are the errors, i have gone through log files . Unfortunately, there are no entries in the log file.
So, How to know what are the errors encountered by the wizard ?
Any thoughts!!!
-Naren
Did you review if their were any specific logs in the temp directory?
Also, I believe the debug logger coupled to com.pegarules.generated.pega_procom_archivepurge could potentially give you further information as to the error.
