Application Rollback not happening using prpcServiceUtils REST API
I am trying to import an application into pega and trying to rollback to the previous state of the system using prpcServiceutils.When I am importing a RAP that contains only Ruleset of an application and only a Data instance import is happening, and after importing when I am trying to rollback using prpcService Utils REST services rollback is successfully happening.But when I follow the same procedure to import a RAP that contains Application and corresponding rules import is happeining but when I try to RollBack to the previous state of the system using the prpcService utils RollBack of application is not happening.Can I know the reason and also the solution to achieve the stated scenario.
