exception in queueing Connect-Rest ,Database rollback caused queue item rollback
Hi
I am queueing a rest service as we are not concerned with response and its a time and also to enhance performance. I have created a request processor and mentioned queued class as "System-Queue-ExecutionRequest-Connect-Default". But whenever I am queueing anything and checking the instance created I am seeing the following error below. Please suggest how to mitigate this issue?
Hi
Database rollback caused queue item rollback: java.lang.Throwable at com.pega.pegarules.priv.util.StackTrace.getStackTrace(StackTrace.java:47) at com.pega.pegarules.session.internal.async.agent.QueueManagerImpl.rollback(QueueManagerImpl.java:1169) at com.pega.pegarules.session.internal.async.agent.QueueManagerImpl.rollback(QueueManagerImpl.java:1138) at com.pega.pegarules.session.internal.async.agent.QueueManagerImpl.rollback(QueueManagerImpl.java:1131) at com.pega.pegarules.session.internal.engineinterface.service.RequestProcessorImpl.processQueue(RequestProcessorImpl.java:701) at com.pegarules.generated.activity.ra_action_processqueue_90bab9d8d8f981f8da8c556128761aab.step1_circum0(ra_action_processqueue_90bab9d8d8f981f8da8c556128761aab.java:160) at com.pegarules.generated.activity.ra_action_processqueue_90bab9d8d8f981f8da8c556128761aab.perform(ra_action_processqueue_90bab9d8d8f981f8da8c556128761aab.java:69) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3527) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:732) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:607) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:980) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1290) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1038) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:920) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:697) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532) at java.lang.Thread.run(Thread.java:748)
Right,
I can see 2 hotfixes with that error message. Maybe you should look into HFIX-44849 or HFIX-45068
