Cognizant
Last activity: 18 Jul 2017 10:23 EDT
Problem with Connect-REST Wizard?
Actually I have CPM Framework installed on top of PRPC and we have our application.
The problem is when create new Connect-Rest the wizard is throughing an error of Data-Party class problem.
I'm unable to generate the Rules.
Can anyone help us ASAP on this like where we need to mention the pyWorkParty class?
Vyas Raman Loka.
***Updated by moderator: Lochan to close post***
It's a problem with CPMFS and not CPM. This is happening because Work-.pyWorkParty is overridden in CPMFS and the class is changed to PegaCPMFS-Data-Customer. Please raise a SR to get it fixed. You can provide link to this mesh post when raising a SR
As a workaround to proceed, you can do a private checkout of the pyWorkParty property in pega ruleset and run the wizard.
Can you please provide more details - Pega version, CPM version, error messages, screenshots ?
Cognizant
Cognizant
What is the difference between CPMFS and CPM.
Updated: 23 Jun 2015 12:28 EDT
Hi Vyas,
CPMFS is an Application which is built on top of CPM - it provides additional functionality for Financial Services.
Note: CPM is now known as 'Pega Customer Service':
https://collaborate.pega.com/discussion/creating-pega-customer-service-solutions-71-issues-lab
Hope that helps,
John
Updated: 16 Jul 2015 11:34 EDT
Hotfix provided by GCS.
Cognizant
I'm unable to neither search nor open given SR.
PEG
You can check this SA-12013 and here is the HotFix-22851
The post including the SR # has been changed. In general, we want to avoid adding links/content that will only be available to a limited set of community participants (access to an SR is limited by account). We are in the process of modifying the Community Rules of Engagement to reflect this policy.
