LTIMindtree Limited
Last activity: 7 Apr 2022 11:36 EDT
Allow rule check out and switch application
I have an operator who has access to two different applications. The operator uses OOTB switch apps navigation to switch between the two. One of the application requires the operator to have all the allow rule check out option available while the other doesn't need that.
I have tried to set the pyAllowRuleCheckOut property to true in ApplicationProfileSetup. I have also set the pxPersonalRulesetName to pxRequestor.pyUserIdentifier + "@", but its not working. I am getting an error saying "Rule-Ruleset-Version<pxRequestor.pyUserIdentifier>@:01-01-01 does not exist" when I am trying to check out the rule from configuration tab in the user portal.
Note : Production ruleset is available in the profile which is unlocked.
Anyone has any idea, or has faced similar issue earlier?
