Allow rule check out access to Agent
We are using an activity to create a rule which is in a unlocked ruleset with use checkout enabled.
we are facing the below error when we use an standard agent to run this activity.
Error Message: Trying to save an invalid page: Trying to save an invalid page: page is not valid
.pyRuleSet: Your Operator ID does not allow Rule Check Out making it impossible to save a record belonging to a RuleSet that requires Check Out.
I want to understand how to give allow rule check out access to the agent. When operator runs the activity was able to save the rule but was unable to when the same operator uses an agent to run the activity.
Thanks in advance.
