Ernst & Young LLP
Last activity: 28 Aug 2018 15:36 EDT
Rule Check out Failed
Hi ,I'm Trying to Checkout a Rule , Pega is not allowing me to do that. It say's that Rule set is locked , Please save it into the Unlocked Rule set Version. However , The Rule set is not locked and "Allow rule check out option was enabled for my Operator ID" instance. I have resolved this issue before by clearing my Browser cache , but some times still it reappear's even after that.
Can you run Tracer to review where it is failing and see the associated data?
Also you can open the Ruleset version > Security tab > Use Check Out(checkbox should be enabled)
Ernst & Young LLP
It is enabled.
Ernst & Young LLP
I'm not able to see the checkout option at all.
What do you see on the Clipboard for pxRequestor.pyAllowRuleCheckOut?
Ernst & Young LLP
It is set to true.
I'm not sure why it is not working then. Let's see if anyone else has seen this and responds.
You can click on the lock icon to see the specific message related to the current status of the rule.
Public Safety Canada
This comment/reply has been branched into a new post
