  ASB
NZ
Last activity: 31 Aug 2016 0:36 EDT
AES does not show the available listeners on the monitored nodes
I have AES 7.17 set up and monitoring a few different nodes all running Pega 7.19. Do i have to do anything to get AES to be able to view the listeners running on the nodes? It doesn't detect any listeners on any nodes.
***Updated by moderator: Lochan to add Category***Included SR details***
  ASB
NZ
This issue has been fixed. The instances in AES of PegaAES-Data-Nodes had no values in for “New Connection String” Once I added them in like below
https://<url>/prweb/PRSOAPServlet
Then it all started working correctly.
  Pegasystems
1) Are you able to see other details like requestors, agents etc. (tabs next to listeners)?
2) The monitored node for which the listeners is coming empty, are there any exceptions on that monitored node or on AES node?
  ASB
NZ
Hi Rajiv
Thanks for your help. In answer to your questions
- I cannot get anything back for requestors or agents either.
- When i run the search for agents I get the error "The system cannot infer the transport information from the [unable to determine] URL." . If i search for requestors i get no results but in the lotgs i get this error "XML parsing failed com.pega.pegarules.pub.PRException: Caught exception parsing XML stream "
Can you please attach the log files?
Does behavior look similar to the issue described here: https://community.pega.com/support/support-articles/aes-quiesce-management-feature-does-not-work
Hi Matthew,
Also can you set the log level to 'DEBUG' for the 'invokeaxis2' activity rule which will print the SOAP envelope details in PegaRULES log file, please share the pegarules logs.
And also confirm , whether the monitored node is upgraded PRPC,what is the value of below DSS settings:
Owning Ruleset: Pega-IntegrationEnginePurpose: SwitchToOldAssemblerValue
  ASB
NZ
Hi Abhishek
I answered most of your question in my general post below.
For the DSS I don't have that at all. Should I have it on 7.19?
  Pegasystems
Please take a look at these two PDN posts
https://community.pega.com/support/support-articles/soap-errors-aes-monitored-node
  ASB
NZ
Thanks for taking an interest in this one. I've attached the log file. The following entry
"2016-08-19 12:15:46,141 [-threads-1125739482)] [ STANDARD] [ ] [ AES:07.13] (egaAES_Data_AlertOrigin.Action) ERROR - ExecuteGetActivityData: Connection supplied invalid. Please configure connection in node: e6cda2367b32156a7e8414ba4e0de1e1 Connection: [unable to determine] Inskey: RULE-OBJ-ACTIVITY ASB-FW-WOW-WORK SETUPATTACHMENTPAGE #20160410T231843.353 GMT ID: BLOBRead-4"
occurs when ever i try to look at the listeners.
Abhiskh i turned on the logging but it gave me no extra information. The monitored nodes are a mixture of upgraded nodes (7.16 --> 7.1.9) and some that are fresh 7.19 installs
Rajiv i had a look at your examples but the error messages look different
  ASB
NZ
I've raised an SR for this issue (SR-A94413).
Matt
  ASB
NZ
Thank you for sharing the resolution with the community. This practice is very helpful for users who face simillar questions.
~Vidyaranjan A V | Community Moderator | PegaProductSupport | Pegasystems Inc.
