TCS
Last activity: 5 Dec 2016 4:51 EST
Disable the monitoring nodes in AES
We have 2 AES system, one for DEV and other for TEST.
I am new to AES, my senior created AES in DEV and configured few environments for monitoring.
There is a requirement to configure one of the performance env in TEST, so I have refreshed the AES DEV database to AES TEST database.
As part of post refresh sanity, I have cleared the unwanted nodes/agent schedules in TEST. But still I could see the nodes in TEST that are already configured in AES DEV.
Can anyone please help in clearing the nodes that are configured for DEV in TEST? I believe i need to enable config changes/delete records from database.
Hi Karthick,
In the Pega 7 envioronment (monitored nodes and AES are Pega 7 and AES 7.1.7 or 7.2)
To permanently remove the nodes from the Dev environment, you merely change the endpoint soap url for the AES server in the Predictive Diagnostic Cloud landing page on each monitored node you wish to repoint.
Alternately you can use AES to point the monitored node to a new AES system using the Management tab for the node on the enterprise health landing page.
