Adding customized Process flow in casetype instead of (default) screen flow
Currently as we can see , by default Pega is opening a screen flow called "CreateForm_Default" . If we don't want to use the screen flow and we need our case type to have a different flow e.g. process flow , then we can follow the following steps :
1. Open the default screen flow ,
2. Go to Process tab
3. Click on Open Case type Definition (blue colored button)
Result: A new rule form will open
4.Under "Automatically Launched processes" , Enter the Flow name in Process field.
And You're ready to go!
Kindly let me know if there is another easy way to achieve this .
***Edited by Moderator Marije to change Content Type from Discussion to Question; added capability tags***
