TForce Freight
Last activity: 9 Sep 2024 11:00 EDT
Add History to the resolved cases
Based on requirement , we want to resolve S- cases based on some conditions .
We forgot to add history while resolving.
Is there any way we can manually add history for a workobject.We did try using History-Add method but it is adding empty record in the table .
Is there any other way we can add history memo to resolved cases?
Rashmitha
***Edited by Moderator Marije to change type from General to Product, added Product details and Capability tags****
Reply
Updated: 9 Sep 2024 11:00 EDT
TForce Freight
We are adding a note to the resolved cases using pxAttach note activity instead of reopening the workobject .
Updated: 14 Aug 2024 0:45 EDT
@RashmithaM Did you try using a savable data page in the respective history- class by setting all the required properties. Any challenges there? this is similar to saving the records using the activity(Page-new, property-Obj-save)
LTIMindtree
Which table are you referring here?
pc_history_work
pc_history_data
Or some Pr_history table?
TForce Freight
@Abhishek Tripathi this is the table pc_history_work
LTIMindtree
@RashmithaM were you able to see the values set in the sql step
, when you trace it
My 2 cents...
- Reopen the Workobject - Add the reason for reopening either missing Audit logs or anything meaningful.
- Call History-Add to capture the Audit logs based on your business requirement and resolve the case again.
This will be in line with other cases (no extra audit logs after the cases are resolved).
TForce Freight
@RameshSangiliInstead of reopening the workobject, Do we have any other options?
Sorry, it's not advisable to add audit history after cases are resolved.
TForce Freight
