Datacom group
NZ
Add control regions
I am trying to use the "Add control regions" option to interrogate a windows application comboBox because I was unable to interrogate those using any other way.I followed the following steps to configure control regions in the Openspan.ini file. But I can't perform the performClick test method on the comboBox which I interrogate using the "Add control regions" option.It just seem to try clicking the comboBox but the comboBox getting highlighted and that's it.What would be the problem?Even I tried performClick on a button.the same result I got.
http://help.openspan.com/52/Adapters_Interrogation/Add_Control_Regions_Windows_Tab_Functions.htm
