Control Region use
Windows Application gets Hanged some time when i used to make the selection with Control region, Windows Application shows Not Responding for some time.
I would be surprised if the control region itself were the problem. This is just a rectangle inside of a control that you can click or potentially get text out of if so enabled. If you have performed the testing to confirm that the CR is the cause (i.e. deleting it does not cause a freeze), I would suggest that you open a support request.
