Tata Consultancy Services
Last activity: 6 Dec 2017 6:32 EST
Adaptive Decision Manager service is not configured or not available
I am using Pega 7.3 personal addition.While saving Adaptive model getting error like"Adaptive Decision Manager service is not configured or not available". I have tried to add a adaptive decision manger node at adaptive decision manger tab of Decisioning: Services landing page. But adding node is failing with status "Joining_ Failed" and error message like Below"
IllegalStateException: Required service ServiceDependency{serviceName=DDS, instance=Default} is configured to run, but none of the nodes are actually running
Please suggest me what should we do to create adptive model rule sucessfully and execute correctly. How to add addaptive decision manager node.is there any extra installation of jarfiles required to add this node.
Please share suggestions ASAP.
Could you please verify if the DDS node is running and in NORMAL state in the Decisioning --> Infrastructure --> Services landing page for DDS.
If you are unable to start the DDS node; I would suggest creating a support request, as it would require further investigation. Make sure to attach necessary PegaRULES and Cassandra logs in the SR.
Cheers,
Santhosh
