Booz Allen Hamilton
Last activity: 5 Mar 2020 9:16 EST
Actions menu is missing when we run the report definition after the upgrade to Pega 8
When we run any report definition, the Actions menu (export to excel, etc) is missing after the upgrade to Pega 8.1.3. There is no change made to the Report viewer. Please advice if there is any system settings to be changed.
Thank you.
Confirm whether the Action menu button is missing or the Menu items from the actions button is missing.
If the Action menu items are missing then check whether "Enable actions" checkbox is enabled under "Report Viewer"and the options are selected from the list. Below is the screenshot for reference,
Select the menu items from the "Options" button.
If the Action menu button is missing kindly verify the below configurations,
Check which header section the report is using. You can identify the same by using Live UI tool.
Does "Edit report" button is visible in the report header?
By OOTB, the report uses "pyReportEditorHeader" header section. Kindly verify the same and provide screenshots to look further.
Geeda.
Booz Allen Hamilton
Hi
In the Reportviewer tab, the Enable actions check box is checked. It is the Action Menu button missing. When I checked the header section, it shows it displays the "ReportSectionMain" And also non of the Action item is seen. I have the attachment.
FR
Is the behaviour different with a brand new Report instead of the upgraded ones?
Booz Allen Hamilton
Hi
Any report definition that I run have the same issue. But I am able to see the Action menu, if I open in the older version. Also it is only 2 of us in the team having this issue. Others are able to see the Actions Menu. Is there any system settings that we need to change?
The section used to display the actions button is the "pyReportEditorHeader". Could you perform a Revalidate of this section?
Configure->Systems->Release->Upgrade->Validate and select this section.
Also just wanted to know if the access group that your operator is included in, is different from your teammate who is able to see the button.
Booz Allen Hamilton
The Accessgroup is not different from my teammate. And I am not able to select the section to revalidate.
Swedbank AB
SE
If accessgroup is same and if it is working others then it is cache issue. Try to open the section through live ui and do private edit of pyReportEditorHeader section check and also If your not finding pega-reporting ruleset in revalidate window then try to add that ruleset temporarily in your application and after revalidate save you can remove.
Booz Allen Hamilton
I tried to open in the Live UI, RRFiltersAndDropzone section opens. I also tried to do a private edit of the pyReportEditorHeader section and it did not work. Finally tried to fine the ruleset in valideate and as it was not available, added Pega-Reporting:08-01 to the application ruleset and saved. Later tired to find it in the Configure->Systems->Release->Upgrade->Validate and did not find it. Not sure what else to do.
Hi Nalins,
Thanks for posting the query.
Could you please check the visibility condition on the actions button in the particular section which might be the reason to not show the button at run-time.
Could you please navigate to Configure > User Interface > Application Readiness > HTML5
Select UI Element tab and check if there is any update button.
Please attach the screen-shot of the same page.
Booz Allen Hamilton
Hi
I have attached the screen shot that you requested. I expanded all the menu and did not find any rule that needed an upgrade.
It looks like menus are not upgraded. Go ahead and click on the Upgrade 'Show menu' button.
Booz Allen Hamilton
Yes, clicked on the button mentioned. But no luck.
Hi, could you review the below suggestions -
a. Login with the default operator [email protected] and the password and try if you can reproduce the issue. Or add PRPC:Administrator access group to your operator record, and then switch the application after you have logged in. Please run any OOTB report definition and see if the issue reproduces.
b. If the issue does not reproduce (my hunch is - issue might not reproduce!), then something is overriding in your application causing the Actions menu not to show. Try to use the OOTB skin rule pyEndUser to ruleout any skin related issues.
c. If the issue does reproduce with OOTB operator / access group, then, it appears you have missed an upgrade step. You can engage us with an SR and we would be glad to investigate the issue further for you.
Thank you
Booz Allen Hamilton
Hi
The option A worked. We have a Foundation layer, Framework layer and then the Application layer. In the Foundation layer the Actions menu is seen. But in the FW Layer and the Application layers, it is not. I could not find, where it got overridden.
Even i am facing same issue post upgrade to 831. When i login as prpc:administrator i am able to see the actions and with application, it is not visible.
Before upgrade, the reports were displaying the actions. Please provide inputs
Panimozhi T
Thank you
