Tricon Residential
Tricon Residential
Tricon Residential
Posted: Aug 8, 2019
Last activity: Jun 5, 2020
Last activity: 5 Jun 2020 13:38 EDT
Issues reading from the BLOB when running a report definition
I am currently working in an environment that is being run on the Pega Cloud.
I am unable to run a report definition on an unexposed column.
At the moment, there is no intention of exposing the said columns.
What would the necessary steps be for resolving this issue?
Error:
An error occured on executing the query for the report definition - There was a problem getting a list: code: 0 SQLState: 42883 Message: ERROR: function pegadata.pr_read_from_stream(unknown, character varying, bytea) does not exist Hint: No function matches the given name and argument types. You might need to add explicit type casts. Position: 8 DatabaseException caused by prior exception: org.postgresql.util.PSQLException: ERROR: function pegadata.pr_read_from_stream(unknown, character varying, bytea) does not exist Hint: No function matches the given name and argument types. You might need to add explicit type casts. Position: 8 | SQL Code: 0 | SQL State: 42883
