capgemini
FR
Last activity: 15 Mar 2021 15:32 EDT
[8.5] Lot of bugs
I'm using pega academy 8.5.
As you see one screen there are 3 arrow. Most of the times, when clicking on i got a infinit loader.... Need to retry again and again or use a trick... For example i would create a text area input : I need to first submit a "single line" and after that edit it to change by "paragraphe"....
PEGA 8.5 have MANY bugs. I can't found a feature inside pega app studio to report you bug when i saw it....
How can i help more ?
Cordially,
E.A
Response of the support which seems to work :
"We have discovered that if you tab out of the Field control after entering the name, and then select the Type, the page does not freeze"
Hope this will help other people.
