Issue
After updating to Pega Infinity™ ‘25, clients see errors while attempting to upload files with special characters in the filename.
Symptoms and Impact
"File <filename> does not exist" on the screen.
“(Data-WorkAttach-File)pxFileNotFound [filename]” in the trace.
File cannot be uploaded or attached.
Steps to Reproduce
Update to Pega Infinity ‘25.
Access pxUploadFile activity for file attachments (for example by using pyAttachmentScreen section).
Attempt to attach a file containing special or non-ASCII characters in the filename, Example: üöä.F.pdf. Error “pxFileNotFound“ is displayed.
Root Cause
This is a defect in the Pega Platform related to an encoding limitation that prevents the system from correctly interpreting filenames with special characters.
Solution
This has been resolved in Pega Platform release 25.1.3.
A Platform level fix for the upcoming release is also planned.
Hotfixes are available for these earlier impacted release of Pega Infinity ‘25:
- HFIX-D951 – Pega Platform release 25.1.2
- HFIX-D334 – Pega Platform release 25.1.1
You can request the hotfixes from the My Support Portal by selecting the Existing Hotfix ticket type. For more information on creating a support ticket, refer to My Support Portal FAQs.
