Knowledge Expert
FR
Last activity: 10 Mar 2025 11:04 EDT
PKM Portal - How to search for all articles whatever the status
In PKM Portal, our customer want to search without filter on status but it seems not possible
Existing behavior allow to search article but the filter status is mandatory. There is two aggregate status "Awaiting Publication" and "Active Statuses" that allow to search on multiple status; but there is not aggregate value like "All Statuses". In attachment a screenshot of the standard screen
I check the rule behind the search and it's not possible to customize it (details: it's possible to customize the UI by adding a value like "All Status" in property KMpyStatusWork but it's not possible to customize the activity "KMSearchContent" - data source of data page D_ExportContentList used to display the article search result. Indeed, this activity is Final and I can't consider the new value of property inside).
So I have two questions:
- Do you know if an OOTB behavior allow to search PKM article without filter on status ?
- If no, is it possible to make the activity "KMSearchContent" as Available to allow customization on search behavior ?
- Otherwise, is it possible to implement a change to add the value "All Statuses" in the list ?
