Evonsys
Last activity: 15 Jan 2025 23:39 EST
Submitting Local Action from Optimzed Grid causes a Harness Reload
We have a screnario where we have our Worklist created on Pega's Optimized Grid. On this grid we have a menu option that lists a series on Local actions that the user can take. These local actions are displayed over Overlays.
When we open up a Local Action complete the single page task over the Overlay and submit the Local action we are observing a full harness reload. (Note same issue is observed in Modal Dialog as well)
On checking further we observed that the issue is seen only on Optimized Grids and not on legacy grids. From the browser network trace and Pega tracer output I could see that the Close Modal function triggers a Reload section, but in case of Optimized Grids its calling the pyDeleteDocumentPg activity which actually triggers the Reload Harness.
I have tested the same on Pega's default DM sample application, and the same is observed. Has anyone faced the issue earlier, is there any configuration changes that we can apply to stop this behavior or is it a issue from the Optimized Grids in Pega. Thanks
Tushar
