Posted: Jul 25, 2024
Last activity: Aug 6, 2024
Last activity: 6 Aug 2024 13:46 EDT
Hazel cast caching
- How is Cache maintained, What data is present in Cache.
- Do the Cache have an expiry defined and gets cleared . Is it tied to a session.
- Does the Cache should be encrypted at rest.
- Credentials used to access cache are stored securely ?
- Credentials used to access cache can be auto rotated ?
- Do we store Payments and Highly confidential data in Cache ?
@RojaB Hazelcast is used for cluster communication in Pega, helping to maintain a common cache across all Pega nodes in a cluster environment. The cache can contain various types of data, including Customer Data Keys (CDKs) for encryption and decryption purposes. The cache uses a size-based eviction policy, where old cache entries are removed once the cache is full. Pega supports configuring authentication credentials using a secret in an external secrets operator, which suggests that credentials used to access the cache are stored securely. However, the context does not provide information about whether the cache is tied to a session, has a defined expiry, should be encrypted at rest, whether credentials used to access the cache can be auto-rotated, or whether payments and highly confidential data are stored in the cache.
Apache Ignite vs Hazel Cast
Cache in multiple node setup in Pega
Caching in Pega 7.3
Platform cipher - Customer data key (CDK) cache management
Caching in Pega 7.3
External Hazelcast in your deployment > Connection authentication between P
How does Pega 7 use Hazelcast?
