JCS Lanit - BPM
RU
Last activity: 25 Aug 2016 4:36 EDT
How does Pega 7 use Hazelcast?
Does anybody know which features of Pega 7 platform leverages Hazelcast in multi-node configuration?
Updated: 20 May 2016 9:15 EDT
JCS Lanit - BPM
RU
One of usages is DSM. In DSM installation guide 7.2 it is stated that Hazelcast is used to build a cluster of D-nodes.
What else?
In addition to DSM ( Decision Management), Pega uses Hazelcast distributed clustering technology to share data and send events between server nodes
JCS Lanit - BPM
RU
Hi Arvind,
Could you please clarify which data is shared and what events are sent between nodes using Hazelcast?
Best regards,
Alexander.
PEG
PL
The installation guide has some basic info: https://docs-previous.pega.com/pega-719-platform-installation-guide-oracle-websphere
Both hazlecast and elastic search are little bit explained.
JCS Lanit - BPM
RU
Hi Rajeev,
Thank you for your reply. Unfortunately, explanation provided in the installation guide is rather depthless, that is way I decide to raise this question on Mesh.
Best regards,
Alexander.
Hello Alexander,
Under the covers, 71ML7 incorporates two big architectural changes - elastic search and hazelcast.
Traditionally, PRPC clustering was 'loosely coupled' - PRPC nodes did not communicate directly with each other by default; they simply shared the database. The only cross-node communication normally implemented were SOAP calls to the Lucene Index owning node, and the SOAP calls were often set using a proxy or load balance URL. PRPC did not open ports or directly talk cross-node.
In ML7, PRPC clusters are tightly coupled.
a- Lucene search has been replaced by elastic search. With elastic search, the indexing nodes open a communication port for communicate with both index-client and other indexer nodes.
b- Hazelcast has been added as a core engine component. It is currently used for DSM and agent management but later will replace use of database for lock management. Each PRPC node opens a unique port for hazelcast communication to other PRPC nodes.
By default, elastic looks for an available listen port in 9300-9399 range. You must validate that ports 9300-9399 are unblocked / available. There are system settings to override the elastic port range.
I believe Hazelcast looks for an available port in the 5700-5800 range (have not verified). You must validate that ports 5700-5800 are unblocked / available. I believe there are system settings to override the hazelcast port range.
Hello Alexander,
PRPC servers must be able to cross-communicate via TCP/IP. There will likely be firewall changes needed in production and cloud environments. I do not believe that PegaCloud has the hazelcast and elastic port blocks open by default.
Two new columns are added to pr_sys_Statusnodes - pyclusteraddress holds the hazelcast IP address/port, pyindexeraddress holds the elastic address/port.
Kindly let me know if this information might helped you.
Mahesh
Updated: 23 May 2016 3:49 EDT
JCS Lanit - BPM
RU
Hello Mahesh,
Thanks a lot for your reply and detailed explanation.
Could you please provide some extra details on how Hazelcast is used for agent management?
Best regards,
Alexander.
Optum
One more question is does this Hazelcast affect single node environment or only affects multinode systems?
