How to enable hazelcast cluster in Pega 7.3
I am looking for hazelecast enable in Pega 7.3. I gone through some cotent here, but i still need some more info.
In my env we are using 20 nodes running in Websphere with Pega 7.3.
Here how i can do a setup with hazelcast using IP Add and Port range.
Should i add some parameters in prconfig.xml with nodes info and need to open ports is that enough.
Can any one give more info and sample prconfig.xml OR cluster parameters to add in prconfig file.
