Hazelcast Issues Pega 8
We are observing a lot of issues related to hazelcast in our environment.
Sometime hazelcast engine goes down still the prsysstatus node tables gets updated. PegaCluster log stops getting updated.
2019-08-17 04:25:01,920 [331.cached.thread-46] [ ] [ ] ( hazelcast.instance.Node) INFO - [xxxxx]:5706 [a948064bf1085f5cb78ac1448bc1f331] [3.10] Shutting down node engine...
2019-08-17 04:25:05,320 [331.cached.thread-46] [ ] [ ] (zelcast.instance.NodeExtension) INFO - [10.73.198.36]:5706 [a948064bf1085f5cb78ac1448bc1f331] [3.10] Destroying node NodeExtension.
2019-08-17 04:25:05,320 [331.cached.thread-46] [ ] [ ] ( hazelcast.instance.Node) INFO - [xxxxx]:5706 [a948064bf1085f5cb78ac1448bc1f331] [3.10] Hazelcast Shutdown is completed in 106401 ms.
2019-08-17 04:25:05,320 [331.cached.thread-46] [ ] [ ] (azelcast.core.LifecycleService) INFO - [xxxxx]:5706 [a948064bf1085f5cb78ac1448bc1f331] [3.10] [xxxxx]:5706 is SHUTDOWN
2019-08-17 04:25:05,321 [331.cached.thread-46] [ ] [ ] (azelcast.core.LifecycleService) INFO - [xxxxx]:5706 [a948064bf1085f5cb78ac1448bc1f331] [3.10] [xxxxx]:5706 is MERGE_FAILED
We get Pega0090 alerts.
A lot of times there are communication failures between members.
Reason: Exception in Connection[id=602, /yyyyy:5707->/yyyyy:55601, endpoint=[yyyyyy]:5706, alive=true, type=MEMBER], thread=hz._hzInstance_1_a948064bf1085f5cb78ac1448bc1f331.IO.thread-in-1][STACK][java.io.IOException: Connection reset by peer<CR> at sun.nio.ch.FileDispatcherImpl.read0(Native Method)<CR> at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39)<CR> at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:223)<CR> at sun.nio.ch.IOUtil.read(IOUtil.java:197)<CR> at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:380)<CR> at com.hazelcast.nio.ssl.SSLChannel.read(SSLChannel.java:189)<CR> at com.hazelcast.internal.networking.nio.NioInboundPipeline.process(NioInboundPipeline.java:129)<CR> at com.hazelcast.internal.networking.nio.NioThread.handleSelectionKey(NioThread.java:383)<CR> at com.hazelcast.internal.networking.nio.NioThread.handleSelectionKeys(NioThread.java:368)<CR> at com.hazelcast.internal.networking.nio.NioThread.selectLoopWithFix(NioThread.java:289)<CR> at com.hazelcast.internal.networking.nio.NioThread.run(NioThread.java:224)
Sub clusters getting formed
***Edited by Moderator Marissa to update platform capability tags; update SR Details****
