       Virtusa
  Virtusa
   Virtusa
          Posted: Feb 3, 2022
        Last activity: May 2, 2022
      Last activity: 2 May 2022 16:21 EDT
Platform cipher - Customer data key (CDK) cache management
As per the documentation: (Ref: https://docs-previous.pega.com/security/85/encryption )
- Pega Platform creates an initial customer data key (CDK) based Customer master key (CMK) (configured in KMS/KeyStore instance).
- The CDKs are stored in encrypted format in the Pega database. On node start up, KMS is called to decrypt the CDKs stored in the Pega database, using your master key.
- Customer data key (CDK) is used by Pega Platform for actual encryption and decryption purpose.
We are looking answers for below questions. Please suggest
- Is generated Customer data key (CDK) is stored in cache memory as well for quick access? or it referred each time from database for data encryption/decryption?
- What is the duration (in minutes/hours/second) for which Customer data key (CDK) is maintained in cache memory ?
- What is the impact of the server restart with respect to the Customer data key (CDK) maintenance/initialization?
Thank you in advance.
Abhinay
***Edited by Moderator Marije to add Product and Version***
***Edited by Moderator Marije to add Support Case Details**
