Unable to add suggested articles to a case
Hi there,
In CS portal I am about to suggest articles to a case using "Configuration option." I am able to search for the articles in "Search Articles to add." After selecting an articles from the results and click on save I am seeing sucessfull message. But no articles are getting saved. Below I have attached screenshots of the results.
Regards:
Manoj K
***Edited by Moderator Marissa to add Capability tags***
@KATTAM13
Check the rule CSFASuggestedArtilces in global search and open the exact instance for that class then in case its inside open RS of your implemenation try to delete from there.
