Banca Generali
IT
Last activity: 17 May 2024 15:51 EDT
CosmosReact WebPortal does not load from LDAP (custom - SSO)
Hi all,
I am experimenting Pega Cosmos building a new Application. I created the application and developed a new case. From business it's required that the new Application must be accessible only by LDAP (Custom Authentication Activity, so no LDAP pure is defined).
I defined and added the WebLDAP authentication service on the App and I successfully logged in to Dev Studio.
Now, I am wondering to Log in to Web Portal directly. So I configured an Access Group which links to the new Application and it has the WebPortal (defined as default) as Available portals. When I try to login the browser shows me a blank page. If I consult the console dev (chrome one) I can see an error:
Refused to load the script 'https://c11n-prod-eu-south-1.constellation.cloud.pega.net/c11n/8.7.6-1181/pega-bootstrap-component.js' because it violates the following Content Security Policy directive: "script-src 'unsafe-inline' 'unsafe-eval' 'self' http://www.google-analytics.com https://ssl.google-analytics.com https://unpkg.com/swagger-ui-dist@3/swagger-ui-bundle.js". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
The stranger things is that if I refresh the page then it works.
I am using a URL composed by query param so I have the URL composed such:
myapp.pegacloud.net/prweb/WebLDAP1/app/ApplicationA/STANDARD?Param1=value1&Param2=value2
Hi all,
Instead, when I refresh the page the url become:
and then it works.
If I do not use WebLDAP with an operator defined with the AG that links to the WebPortal directly it works. Does anyone can help me?
Best,
Vincenzo
