Case Archving with exposed properties not working in search
After configuring the case archiving of a case type in a test envirnonment I tried to search the cases using the values defined in some exposed properties (effectively defined in the db work table) but wasn't working. It seems like the only search I can do it's using the case Id, not usefull then.
Based on the documentation i read this "During archiving, only exposed properties are indexed by default." so i don't understand what is missing and
***Edited by Moderator Marije to add Case INC-B18501 tags***
