Last activity: 15 May 2024 9:16 EDT
Startup Error while deploying external hazelcast in 883 version
Hazelcast startup is interrupted while deploying external hazelcast on 883 version in client managed cloud on k8s, statefulset is created but the first pod fails to come up clean. Logs on the pods indicate an issue with a config file, please see below.
Am using the latest docker image for clustering-service:1.3.15.
Has anyone encountered such issue before? Appreciate any insights on this one. Thanks in advance.
Apr 19, 2024 10:02:55 PM com.pega.hazelcast.v5.internal.config.AbstractConfigLocator INFO: Loading configuration '/opt/hazelcast/customconfig/hazelcast.xml' from System property 'hazelcast.config' Apr 19, 2024 10:02:55 PM com.pega.hazelcast.v5.internal.config.AbstractConfigLocator INFO: Using configuration file at /opt/hazelcast/customconfig/hazelcast.xml [Fatal Error] :96:66: The reference to entity "t1" must end with the ';' delimiter. Apr 19, 2024 10:02:55 PM com.pega.hazelcast.v5.config.XmlConfigBuilder SEVERE: Failed to parse /opt/hazelcast/customconfig/hazelcast.xml Exception: The reference to entity "t1" must end with the ';' delimiter. Hazelcast startup interrupted. The reference to entity "t1" must end with the ';' delimiter.
