Accenture
SG
Last activity: 15 Oct 2024 23:48 EDT
Error encountered while deploying Pega INfinity 24.1.1 using Pega Helm Charts and Docker images
Hi Team,
I am trying to deploy the Pega Infinity Version 24.1.1 using pega provided docker images. I am able to deploy the addon and backing services. However while deploying the pega.yaml , I am facing below errors:
Error: HZ_CS_AUTH_USERNAME & HZ_CS_AUTH_PASSWORD must be specified in hazelcast client server mode deployments.
I have provided the username and password in pega.yaml file with below parameter, but still encountered above error.
username: ""
password: ""
To overcome, i have updated the deployments pega-batch with env variables and did not observe the above error. However after updating, I am still facing error as shown below:
Hi Team,
username: ""
password: ""
Pod Logs:
Authentication failed. The configured cluster name on the client (see ClientConfig.setClusterName()) does not match the one configured in the cluster or the credentials set in the Client security config could not be authenticated\n\tat com.pega.hazelcast.v5.client.impl.connection.tcp.TcpClientConnectionManager.checkAuthenticationResponse(TcpClientConnectionManager.java:1059)\n\tat com.pega.hazelcast.v5.client.impl.connection.tcp.TcpClientConnectionManager.onAuthenticated(TcpClientConnectionManager.java:935)\n\tat com.pega.hazelcast.v5.client.impl.connection.tcp.TcpClientConnectionManager.getOrConnectToAd
Other Exception:
Exception in thread "StartupTaskUtil INITIALIZE_STREAM_SERVICE" com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.dsm.dnode.api.prpc.service.ServiceManager.bootstrap(ServiceManager.java:212)
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask$1.run(StreamServiceInitializationTask.java:80)
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask$1.run(StreamServiceInitializationTask.java:77)
at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:77)
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper$2.run(ServiceHelper.java:295)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1379)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1122)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:929)
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:288)
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:150)
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.initStreamServerServiceAndValidate(StreamServiceInitializationTask.java:77)
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.runTask(StreamServiceInitializationTask.java:51)
at com.pega.pegarules.session.internal.async.startup.StartupTask$1.run(StartupTask.java:55)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:895)
at com.pega.pegarules.session.internal.async.startup.StartupTask.run(StartupTask.java:48)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.dsm.dnode.impl.prpc.service.ServiceDefinition.instantiateService(ServiceDefinition.java:158)
at com.pega.dsm.dnode.impl.prpc.service.ServiceDefinition.getDsmService(ServiceDefinition.java:110)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1655)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:913)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578)
at com.pega.dsm.dnode.api.prpc.service.ServiceManager.bootstrap(ServiceManager.java:367)
at com.pega.dsm.dnode.api.prpc.service.ServiceManager.bootstrap(ServiceManager.java:209)
... 18 more
Caused by: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
at com.pega.dsm.dnode.impl.prpc.service.ServiceDefinition.instantiateService(ServiceDefinition.java:150)
... 28 more
Caused by: com.pega.platform.stream.StreamServiceException: Failed to configure StreamAPI provider
at com.pega.platform.stream.StreamServiceConfiguration.initProviderConfig(StreamServiceConfiguration.java:281)
at com.pega.platform.stream.StreamServiceConfiguration.<init>(StreamServiceConfiguration.java:178)
at com.pega.platform.stream.StreamServiceConfiguration.<init>(StreamServiceConfiguration.java:165)
at com.pega.platform.stream.StreamService.getConfiguration(StreamService.java:101)
at com.pega.dsm.dnode.api.server.StreamServerService.shouldExposeKafkaForStreamAPI(StreamServerService.java:1062)
at com.pega.dsm.dnode.api.server.StreamServerService.getDeployment(StreamServerService.java:250)
at com.pega.dsm.dnode.api.server.StreamServerService.<init>(StreamServerService.java:167)
... 33 more
Caused by: java.lang.IllegalArgumentException: pega-pega-stream must be defined with {stream.name}
at com.pega.platform.stream.StreamNamePatternConverter.getStreamName(StreamNamePatternConverter.java:71)
at com.pega.platform.stream.StreamServiceConfiguration.configureStreamNamePattern(StreamServiceConfiguration.java:410)
