Folksam
SE
Last activity: 8 May 2024 5:04 EDT
How to check the index of the page list in a when condition in Datatransform
My scenario:
ClaimDataPage.ClaimData.CustomerStatusLis()... I need to find whether the subscript of pagelist CustomerStatusList()> 1, then Set Customer status is equal to previous status else blank
Updated: 8 Apr 2024 6:52 EDT
Evonsys
Iterate over the page list ClaimDataPage.ClaimData.CustomerStatusLis() in your data transform or activity and use the pre condition as
.pxListSubscript>1 / Param.pyForEachCount>1
If true continue whens or skip step
In the step set the value of CustomerStatus based on your requirements
Evonsys
If you are iterating on the pagelist then you can use Param.pyForEachCount.
Alternatively you can also use property pxListSubscript to evaluate your when condition.
naveen souda
Folksam
SE
@SrijitaB if I use pxListSubscript in a when Condition , what exactly has to be used to refer the pagelist which am looking for... ClaimDataPage.ClaimData.CustomerStatusLis()
Evonsys
700Apps
SA
sample when Condition :
D_GetRole[UserID:OperatorID.pyUserIdentifier,Role:@pxEvaluateDecisionTable(Param.PageListProperty+"("+.pxListSubscript +")","ABC").pxResults(1).myRecord
Maantic Inc
In the data transform while looping through the pagelist ClaimDataPage.ClaimData.CustomerStatusLis(), run a when rule/expression where you check .pxListSubscript>1 or Param.pyForEachCount>1. If the result is true then set your required value.
Folksam
SE
.pxListSubscript>1 do we need to declare something else, this when condition always set to false even when there are CustomerStatusList(1),CustomerStatusList(2),CustomerStatusList(3) are present
Evonsys
You have to use this in context of the pagelist, meaning you have to use the condition inside a loop iterating over the pagelist.
In case .pxListSubscript is not working, try Param.pyForEachCount and see if the pre condition works.
Soham Majumdar Lavanya Gowrinathan Srijita Banerjee
Folksam
SE
It worked with Param.pyForEachCount.
