ibm
CN
Last activity: 25 Mar 2024 0:54 EDT
Edit Application failed
hi team,
When I try to add a new branch to a application following error pops up. Can you kindly help?
Before this I tried to create a new "Case Type" but failed, then I tried again. When I try to add a new branch or edit the application error happens. Error details please see attachment.
Reply
Updated: 24 Mar 2024 23:17 EDT
Maantic Technologies Pvt Ltd.
Try to do a content search of the class which the error is indicating is not present in the system or is in a different application stack.
Use "All applications" option to find in other application stacks as well.
Once you find out the where the class really resides you should be able to identify the problem as well.
Additionally, If you have any built on application, you also start "just saving" the application (s) one by one from the bottom to the top of the application stack to pin down / filter the problem area more.
Lantiqx
Class is not present in system or if it is present it is not present in Ruleset\Branches given in application on build on applciations.
ibm
CN
How to fix this?create class manually and then delete it?
Maantic Inc
It is being referred somewhere in your application which is causing the issue. You need to find and remove the reference from the stack. You can create the class of you need it, but deleting it later will again cause the same issues you see now.
ibm
CN
thanks a lot! I understand the application references the class somewhere.
Can you kindly tell me how to remove the reference from the stack? Or how can I find out the references of the class?
Maantic Inc
First search in the App explorer and see if it pops up in the drill down, from there you can open the class definition and delete it. Else do a content search and make the scope as 'All Applications', you should be able to find it there.
