Cour Justice Européenne
LU
Last activity: 29 Jul 2024 2:28 EDT
Read text in region
When interrogating a screen, the region in blue with black border is defined as "Control_Container" under "frmVerificationInvoiceDetail".
The highlight function does not work correctly.
And the "getText" function does not read any text.
How is it possible to read this region of the screen composed with text lines ?
***Edited by Moderator Rupashree to add Capability tags***
Reply
Updated: 29 Jul 2024 2:28 EDT
@JeanChristopheD17042937 did you log a support ticket?
All information on how to request support can be found in our How To Get Support Support Documents.
Administering Support Accounts
Your company will have had an Account Administrator assigned - locate that person and they will give you the necessary User Roles to access our MSP portal.
Please can you provide a status update here or provide a reply and mark it with Accept Solution if the issue is resolved?
@JeanChristopheD17042937I believe you might want to try the GetText method. It has been a while since I have looked at SAP, but I believe this is how I would handle this. There is a buffer size parameter and I believe that is in bytes. You may need to play wth it to ensure you get all the text.
LU
@ThomasSasnett The bloc in blue is not recognized when interrogating again and highlight focus on another field. Defining a screen region dos not work.
It seems SAP frame does not exist and PEGA does not recognized the screen region.
LU
@ThomasSasnett Screen region is not recognized and GetText function does not work.
@JeanChristopheD17042937Perhaps I misunderstood. The first thing you need to be able to do is interrogate the Control. If you cannot do that directly using the Bullseye, then you can use the Virtual Controls tab in Studio. From here, you can manually add controls that you cannot otherwise select with the Bullseye. Once you do have the correct control interrogated, then (at least according to my internal testing of SAP by a colleague), GetText should work to retrieve the full text.
LU
@ThomasSasnettVirtual control detects a region screen where those informations are displayed but it seems there are overexpose on this region and invisible for the controls . Do you know a solution ?
@JeanChristopheD17042937 Not without access to your application. I suggest opening a support request and someone can look at your application with you to see what can be done. If you do open a support request, please add the INC number to this post.
