Redesign the existing application
We have an application in production which probably needs to be re-designed from scratch due to some design flaws and a new major application version needs to be created. I was thinking of design areas which we need to consider:--
1) Handling of in-flight cases - May be it's safer to execute them using the old flow and new cases should follow the updated path but this may lead to adding additional application to users and they need to switch application for old cases
2) Data model change- if the data model is changed for new application and then it's better to use a separate work table for case storage.
3) Reusability - It's better to rebuild the new application on top of old application so that existing data models, rules can be re-used
Are there any other factors which should be taken into the consideration?
