SE
Last activity: 26 May 2023 6:20 EDT
Different header & footer from second page of PDF -- Using HTMLtoPDF OOTB Acitivity.
I have a requirement to generate a pdf with header and footer from 2nd page which is different from 1st page header and footer. I have referred to multiple threads in PDN but none seems to be helpful.
Is it possible to display different headers and footers from the 2nd page onwards in a PDF using Pega OOTB activity HTMLtoPDF? or do we need to follow procedure to achieve the same.
Note: Content in PDF is dynamic so cannot use merge pdf option.
Could anyone suggest any solution on the same. Thanks in advance!
Kranthi Kumar Javangula
