CapGemini
Different footer for first page of PDF - PDF generation using HTMLTOPDF OOTB activity
I have a requirement to set different footer message for the 1st page and different footer for the remaining pages of PDF.
I am using HTMLTOPDF OOTB activity to generate PDF from Correspondence rule(which consists of HTML code).
Is there any way to set different footer(messages) across pages using HTMLTOPDF activity..?
Could any one please suggest something else..OR
confirm (no way of providing different footers across pages of PDF) from PEGA side.
Note: We are using Pega 7.1.9 version
Anupama P
Likes (1)
Simen Fredrik Brunvand Fredriksen -
Vodafone
Hi Anupama,
Thanks for posting your query on PSC :)
Technical perspective, Pega uses PDML4.jar to convert the HTML Markup to PDF (This is the basic thing happens in the background). Considering your business requirement, request you to design the HTML fragment as per your need and pass the markup to HTMLTOPDF activity. This is the way system has been designed, there is no automotive way to reach your requirement.
Best regards,
Naveen
Infosys
You can try this. Create two different PDFs, One with footer and other without footer and concatenate them
CapGemini
Thanks for your suggestions,
In my requirement, PDF content is not static one. Content may change dynamically based on some properties of clipboard.
So, i can't go for creating two different PDF's with different footers.
ANZ Banking Group Ltd
Hi Anupama,
We have implemented this requirement.
I will share the approach once i ma free.
Mahesh
CapGemini
CapGemini
Hi Mahesh,
Could you please share the approach that you have used for different footer across PDF pages.
Anupama
Hi Anupama,
Please find the below HTML stream which will be used to generate the different Header and footer and it need to pass PD4ML Library to generate the PDF
Hi Anupama,
Java Code to Generate PDF :
try{
String sContent=sHtml;
org.zefer.pd4ml.PD4ML pd4ml = new org.zefer.pd4ml.PD4ML();
//pd4ml.resetAddedStyles();
pd4ml.setPageInsetsMM(new java.awt.Insets(10, 21, 0, 16));
pd4ml.enableImgSplit(false);
java.io.ByteArrayOutputStream os=new java.io.ByteArrayOutputStream();
java.io.InputStream is=new java.io.ByteArrayInputStream(sContent.getBytes());
java.io.InputStreamReader ris=new java.io.InputStreamReader(is);
pd4ml.setCookie("JSESSIONID",JSESSIONID);
pd4ml.setCookie("Pega-RULES",PEGARULES);
pd4ml.useTTF(FontsProp,false);
java.net.URL base=new java.net.URL(BASEURL);
pd4ml.enableDebugInfo() ;
pd4ml.protectPhysicalUnitDimensions();
pd4ml.render(ris,os,base);
byte[] byteArray=os.toByteArray();
// Action == Preview
if (Action.equalsIgnoreCase("Preview")){
String sPDF=Base64Util.encodeToString(byteArray);
ClipboardPage workpage = tools.findPage("pyWorkPage");
workpage.putString("PDFDocument",sPDF);
else {
tools.putParamValue("PDFDocument",byteArray);
try{
else {
}catch(Exception e){
throw new PRRuntimeException(e.toString());
Stratosphere Consulting
Hi Mahesh,
1.what/how are you setting JSESSIONID, PEGARULES and BASEURL strings?
2. are you able to get images to show up in your implementation?
THanks!
FrontierBPM
Hi Mahesh,
Did you implement this using HTMLToPDF Activity?
If so, could you provide details of how you passed this to the activity?
I am simply trying to hide the header/footer if ${page} = 1, but that is appearing like an impossible feat.
Kyle
I did not use HTMLtoPDF
CapGemini
Please advice some ways to get it done.
Anupama
Agora Group
I have the similar requirement. I have used PD4ML function to implement this functionality. Place the footer in the HTML stream as below. This code has to be placed before the HTML tag or immediately after the body opening.
<pd4ml:page.footer scope="1">
First page footer
</pd4ml:page.footer>
<pd4ml:page.footer scope="2+">
Second page footer
Let me know if you have any questions.
msg-systems
DE
Hi NizamuddinM,
I have attempted your solution, however, I did not manage to achieve the result of having different Footers for first page and the rest, nor to display footer only from the second page.
I tried the following (in both Pega Personal Edition 7.3 on Win7 and Pega 7.2 on Ubuntu):
Basic Setup: Custom pxCreatePDF Activity (in order to Property-Set-HTML param.pyPDFFooterHTMLTemplate and param.skipCommit=true), called by utility shape. PDF Content fed by HTML Rule, named "PdfHtml", (generate for JSP, see below) including my Section also in this activity, assigned into param.HTMLStream.
<!-- tried calling pd4ml here without pyPDFFooterHTMLTemplate being set -->
<html>
<title>
a
</title>
<body>
<pega:include name="mypdfcontentsection" type="Rule-HTML-Section" />
</body>
</html>
HTML Rule, named "PdfHtmlFooter", (generate for JSP) for pyPDFFooterHTMLTemplate is:
Hi NizamuddinM,
<html>
<title>
a
</title>
<body>
</body>
</html>
footer content
<!-- also tried adding html and body tags here with pd4ml being called outside html or inside body -->
<!-- also tried using <pd4ml:footer pagesToSkip="1"> -->
I'm expecting to see 'footer content' only from page 2.
Actual behaviour:
pd4ml tags seem to make absolutely no difference (nor pd4ml:page.footer nor pd4ml:footer).
If tags are set in the PdfHtml, in the places mentioned in my comments: footer is displayed as placed in the text, before everything, once (not in footer zone). PegaPE 7.3 also displays in the Startup CMD: "Error <pd4ml:page.footer> is not recognized!" or "Error <pd4ml:footer> is not recognized!". Couldn't find the error in any logs for Pega 7.2.
If tags are set in PdfHtmlFooter, no errors as above are shown, but:
<pd4ml:footer pagesToSkip="1"> footer is displayed on all pages, regardless of tag
<pd4ml:page.footer scope="2+"> footer is not displayed at all
What am I missing?
Do you have any idea what I could further try? I'm open to suggestions.
Best Regards,
Istvan
CapGemini
Hi Istvan,
I am also facing the same issue, did you find any solution for this..? Please let me know
Anupama
Just tried this but giving a blank footer.
Any idea how we can get this working?
Hi Will,
I see that this is an old post and also noticed you have a related post: Different correspondence footer in first PDF page
Continuing the troubleshooting on the new post is recommeded :)
Thanks!
