Vodafone DE
DE
Last activity: 4 May 2023 15:09 EDT
Correspondence not getting attached inside Split for Each
We are trying to implement a requirement to send various automated emails based on configurations stored on a Page List, for that we wanted to use the Split for each shape. However, when executing a send email smart shape inside of the Split for each, the correspondence rules are not getting attached to the work object. Is this a bug or not a supported configuration? I assume here the problem is with the child requestors inside the split for each. We have tested using versions 8.5.6 and 8.8.2 having the same behavior on both.
Here the current configuration we have for our POC (v 8.8.2)
Here the result once the case is executed, as you can see the history says that the correspondance was attached, however there is nothing on the case attachments.
