User is receiving error while trying to open a case in UI
Hi Team,
We are able to see the below error in logs.Could you please take a look.
NFO: Stopping resource adapter
[1/24/23 21:25:53:391 EST] 0000009f SystemErr R Unable to locate KeyringImpl keyring after trying:
<properties>
wasprdR-pegarules.keyring
aapprib00001043-pegarules.keyring
pegarules.keyring
2:TS011935578/2023-01-25/new_logs1.zip_unpack/1043_logs1/SystemOut.log
[1/24/23 21:30:55:763 EST] 000000b8 SystemOut O 2023-01-24 21:30:55,757 [ aapprib00001043] [ STANDARD] [ ] (tener.ListenerStateManagerImpl) ERROR - Unexpected exception.
com.pega.pegarules.pub.context.InvalidConfigurationException: No such Access Group: Quarks:Administrators for thread STANDARD
From: (A6B56CEA3153DA7EFF50BF82AD46C36C9:BIXFTPServicePackage)
Hi Team,
<properties>
pegarules.keyring
at com.pega.pegarules.session.internal.authorization.context.GlobalContextCache.getBasicApplicationContext(GlobalContextCache.java:431)
at com.pega.pegarules.session.internal.authorization.context.GlobalContextCache.getLocalizedApplicationContext(GlobalContextCache.java:460)
3:
Caused by:
com.pega.apache.http.conn.HttpHostConnectException: Connection to http://pdn.pega.com refused
at com.pega.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:158)
java.net.ConnectException: A remote host refused an attempted connect operation.
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:404)
at java.net.Socket.connect(Socket.java:643)
at com.pega.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:123)
at com.pega.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:148)
For socket exception please verify if the Remote Host is reachable from network prospective.
4:
Caused by:
com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find a 'RULE-NAVIGATION' with the name 'PYCREATEMENU' that applies to '@baseclass'. There were 4 rules with this name in the rulebase, but none matched this request. The 4 rules named 'PYCREATEMENU' defined in the rulebase are:
4 related to applies-to class '@baseclass', but were defined on subclasses: {Data-DecisionPortal, Data-Portal}.
